Webpack Configuration
Merge relies on Webpack to bundle all of the component files. All the code and encoded files are being merged into one bundle sent to UXPin. As a result, your Webpack config has to be built in a way that does not export any external files. For example, do not use mini-css-extract-plugin, but rather rely on style-loader and css-loader to load your CSS into Javascript bundle. For imports of font files or images instead of using file-loader – use url-loader.
If this approach is not compliant with your current Webpack config, please create a separate config for Merge.
Remember to store the location of your Webpack config in UXPin Config file.
module.exports = {
components: {
categories: [
name: "First Category",
include: [
"src/components/FirstComponent/FirstComponent.js",
"src/components/SecondComponent/SecondComponent.js"
wrapper: 'src/Wrapper/UXPinWrapper.js',
webpackConfig: 'webpack.config.js',
name: "Name of your Library"
}Basic Webpack Configs
The following config serves a repository where CSS is served via JS (CSS-in-JS library: Emotion) and SVG icons are being inlined and imported into an Icon component:
const path = require('path');
module.exports = {
entry: ['./src/index.js'],
output: {
path: path.resolve(__dirname, 'build'),
filename: 'bundle.js',
publicPath: '/',
resolve: {
modules: [__dirname, 'node_modules'],
extensions: ['*', '.js', '.jsx'],
devtool: 'source-map',
module: {
rules: [
test: /\.svg$/,
exclude: /node_modules/,
loader: 'svg-react-loader',
loader: 'babel-loader',
test: /\.js$/,
enforce: 'pre',
test: /\.js$/,
loader: 'source-map-loader',
};The following config serves a repository that uses SASS for styling and inlines SVG icons:
const path = require("path");
const webpack = require("webpack");
module.exports = {
output: {
path: path.resolve(__dirname, "build"),
filename: "bundle.js",
publicPath: "/"
resolve: {
modules: [__dirname, "node_modules"],
extensions: ["*", ".js", ".jsx"]
devtool: "source-map",
module: {
rules: [
test: /\.svg$/,
test: /\.(s*)css$/,
use: [
loader: 'style-loader'
loader: 'css-loader',
options: {
importLoaders: 2
loader: 'sass-loader'
loader: "babel-loader",
test: /\.js?$/,
options: {
presets: ['@babel/preset-env', '@babel/preset-react'],
enforce: "pre",
test: /\.js$/,
loader: "source-map-loader"
