Design System Naming Made Easy
Creating a cohesive design system is no small feat, especially when it comes to naming components, tokens, and styles. Designers often spend hours brainstorming terms that are both clear and consistent, only to end up with a jumbled mess. That’s where a tool like our Design System Naming Generator comes in handy. It streamlines the process by turning your inputs into structured, meaningful labels that fit seamlessly into your workflow.
Why Consistent Naming Matters
In UI design, clarity is everything. When every team member—from developers to product managers—can instantly understand what a component does just by its name, collaboration becomes smoother. Thoughtful naming also reduces errors during implementation and makes scaling your design framework much easier. Whether you’re working on a small project or a sprawling enterprise system, having a reliable way to label elements is a game-changer.
A Tool for Every Designer
Our generator isn’t just for seasoned pros; it’s also a fantastic resource for beginners looking to build good habits. By providing a simple interface and logical outputs, it helps you focus on crafting great user experiences instead of getting bogged down in terminology. Give it a try and see how much time you can save!
How does the naming convention work in this tool?
Great question! We use a simple but effective structure like [category]-[type]-[modifier]. For instance, if you input ‘button’ as the type, ‘primary’ as the purpose, and ‘form’ as the context, you might get names like ‘form-button-primary’. It’s designed to keep things logical and consistent across your design system, so your team can easily understand the purpose of each component at a glance.
Can I customize the naming format to match my team’s style?
Right now, the tool sticks to a predefined format to ensure clarity and avoid redundancy. That said, you can take the generated names as a starting point and tweak them manually to fit your team’s specific conventions. We’re working on adding customizable formats in the future, so stay tuned for updates!
What if I don’t fill out all the fields?
No worries—we’ve got you covered. If any field is left blank, the tool will gently nudge you to complete it before generating names. This ensures the results are as relevant and useful as possible. Just fill in the component type, purpose, and context, and you’ll be good to go.
