How to Automate Responsive Design with React Components
By Andrew Martin on 29th November, 2025
    Automating responsive design in React can simplify your workflow and make your components more reusable. Instead of relying on scattered CSS media queries, you can integrate responsive logic directly into your React components using JavaScript. This approach ensures consistency, reduces redundancy, and centralizes your responsive behavior.
    Key Highlights:
    • Use React Hooks like useState and useEffect to detect screen sizes dynamically.
    • Define breakpoints in a single file for consistency across your app.
    • Leverage tools like styled-components, Tailwind CSS, or Material-UI for responsive styling.
    • Create reusable components and custom hooks to manage responsive logic efficiently.
    • Test thoroughly using browser DevTools, real devices, and cloud-based platforms like BrowserStack.
    Build a responsive website in React using Styled Components – Intermediate React Project
    React
    Step 1: Set Up Your React Environment
    To automate responsive design with React components, you first need a properly configured development environment. A solid setup ensures smoother implementation and easier maintenance of responsive features throughout your project.
    Install Core Dependencies
    Start by installing the foundational React packages:
    npm install react react-dom
    Next, decide on your styling approach. Here are some popular options:
    • For CSS-in-JS styling, install styled-components:
      npm install styled-components
      This allows you to write CSS directly within your JavaScript, with dynamic styling based on component props.
    • For utility-first styles, go with Tailwind CSS:
      npm install tailwindcss postcss autoprefixer
      After installation, initialize Tailwind with:
      npx tailwindcss init
      Tailwind’s responsive classes (like md:flex or lg:grid-cols-3) make it easy to create layouts while keeping your CSS bundle size optimized.
    • For pre-built responsive components, consider Material-UI:
      npm install @mui/material @emotion/react @emotion/styled
      Material-UI provides ready-to-use components like Container, Grid, and Box, all equipped with responsive props. For example, you can define column sizes for different breakpoints using props like xs={12} md={6} lg={4}, eliminating the need for custom media queries. It also includes a useMediaQuery hook for detecting screen sizes and rendering components conditionally.
    Many projects combine these approaches – for instance, using Tailwind for layout and spacing and styled-components for more complex, dynamic styling. Don’t forget to install autoprefixer to automatically add vendor prefixes to your CSS, ensuring compatibility across browsers.
    If you need tools for responsive detection, packages like react-responsive or react-use provide hooks and components to simplify media query handling without manually writing CSS.
    Once your dependencies are installed, focus on structuring your project to support scalable and efficient responsive design.
    Organize Your Project Structure
    A well-organized directory structure is key to managing responsive design effectively. Consider the following setup:
    • /components: Store reusable responsive components here, grouped by feature (e.g., /Navigation, /Hero, /Grid).
    • /hooks: Centralize responsive logic with custom hooks (e.g., useResponsive).
    • /styles: Include global styles and a breakpoints.js file to define constants for mobile, tablet, and desktop breakpoints.
    • /context: Add context providers for responsive state management if needed.
    • /utils: Keep helper functions here for tasks like managing breakpoints or formatting.
    For example, in the /styles/breakpoints.js file, you can define your breakpoints like this:
    const BREAKPOINTS = { mobile: 600, tablet: 1024, desktop: 1440 }; export default BREAKPOINTS;
    This setup promotes a component-driven architecture, where you build and reuse documented UI elements instead of starting from scratch. It also makes it easier to integrate popular UI libraries while keeping your custom responsive logic clean and consistent.
    Finally, update your package.json with scripts for development (npm start), building (npm run build), and testing (npm test). To maintain code quality, set up tools like ESLint and Prettier. For quick feedback during development, you can use Vite’s built-in hot module replacement or install react-hot-loader for instant updates as you tweak your responsive components.
    Step 2: Detect Screen Size with React Hooks
    Now, let’s dive into using React Hooks to dynamically track and respond to changes in screen size. This approach allows your app to adjust seamlessly to different window dimensions.
    Using useState and useEffect to Track Screen Size
    React’s useState and useEffect hooks are a powerful duo for monitoring window size changes. With useState, you can store the current window width, while useEffect sets up an event listener to update that width whenever the window is resized.
    Here’s a simple implementation:
    import { useState, useEffect } from 'react';  const MyComponent = () => {   const [windowWidth, setWindowWidth] = useState(window.innerWidth);    useEffect(() => {     const handleResize = () => setWindowWidth(window.innerWidth);      window.addEventListener('resize', handleResize);      return () => window.removeEventListener('resize', handleResize);   }, []);    return <div>Current width: {windowWidth}px</div>; };
    This example initializes the state with window.innerWidth and updates it whenever a resize event occurs. The cleanup function in useEffect ensures the event listener is removed when the component unmounts, avoiding memory leaks. The empty dependency array ensures the listener is added only once.
    To make this functionality reusable, you can encapsulate it in a custom hook:
    import { useState, useEffect } from 'react';  const useWindowWidth = () => {   const [windowWidth, setWindowWidth] = useState(window.innerWidth);    useEffect(() => {     const handleResize = () => setWindowWidth(window.innerWidth);      window.addEventListener('resize', handleResize);      return () => window.removeEventListener('resize', handleResize);   }, []);    return windowWidth; };  export default useWindowWidth;
    With this custom hook, any component can access the current window width by calling const windowWidth = useWindowWidth(). This approach reduces redundancy and keeps your codebase cleaner.
    Optimizing Performance with Debouncing
    Resize events fire frequently as users adjust their browser window, which can lead to excessive state updates and re-renders. To address this, you can implement debouncing, which delays state updates until the resizing stops:
    import { useState, useEffect } from 'react';  const useWindowWidth = () => {   const [windowWidth, setWindowWidth] = useState(window.innerWidth);    useEffect(() => {     let timeoutId;      const handleResize = () => {       clearTimeout(timeoutId);       timeoutId = setTimeout(() => {         setWindowWidth(window.innerWidth);       }, 250);     };      window.addEventListener('resize', handleResize);      return () => {       window.removeEventListener('resize', handleResize);       clearTimeout(timeoutId);     };   }, []);    return windowWidth; };
    This debounced version minimizes unnecessary re-renders, ensuring your app remains efficient even during rapid resize events.
    Defining Breakpoints for Responsive Design
    With screen size detection in place, the next step is to define breakpoints that map screen widths to specific device types. Common breakpoints include mobile (0–480px), tablet (481–768px), and desktop (769px and above). However, you should tailor these values to your app’s design needs.
    Start by centralizing your breakpoints in a configuration file:
    const breakpoints = {   mobile: 480,   tablet: 768,   desktop: 1024,   largeDesktop: 1440, };  export default breakpoints;
    Storing breakpoints in one file ensures consistency across your app. If your design team updates the breakpoints, you only need to edit this file.
    Next, create a helper hook to determine the current device type:
    import useWindowWidth from './useWindowWidth'; import breakpoints from './breakpoints';  const useResponsive = () => {   const windowWidth = useWindowWidth();    return {     isMobile: windowWidth < breakpoints.tablet,     isTablet: windowWidth >= breakpoints.tablet && windowWidth < breakpoints.desktop,     isDesktop: windowWidth >= breakpoints.desktop,     isLargeDesktop: windowWidth >= breakpoints.largeDesktop,   }; };  export default useResponsive;
    This hook returns boolean values for each device type, making it easy to conditionally render layouts or components. Here’s an example:
    const ResponsiveLayout = () => {   const { isMobile, isDesktop } = useResponsive();    return (     <div       style={{         padding: isMobile ? '10px' : '20px',         display: 'grid',         gridTemplateColumns: isMobile ? '1fr' : '1fr 1fr',         gap: isMobile ? '10px' : '20px',       }}     >       <div>Column 1</div>       <div>Column 2</div>     </div>   ); };
    This component automatically switches between a single-column layout for mobile and a two-column layout for desktop. Unlike CSS media queries, this approach allows you to adjust not just styles but also the behavior and structure of your components.
    Using React Context for Global Responsive State
    For larger applications, managing responsive state globally can simplify your code. React Context is perfect for this purpose:
    import React, { createContext, useState, useEffect } from 'react'; import breakpoints from './breakpoints';  export const ResponsiveContext = createContext();  export const ResponsiveProvider = ({ children }) => {   const [windowWidth, setWindowWidth] = useState(window.innerWidth);    useEffect(() => {     const handleResize = () => setWindowWidth(window.innerWidth);      window.addEventListener('resize', handleResize);      return () => window.removeEventListener('resize', handleResize);   }, []);    const isMobile = windowWidth < breakpoints.tablet;   const isTablet = windowWidth >= breakpoints.tablet && windowWidth < breakpoints.desktop;   const isDesktop = windowWidth >= breakpoints.desktop;    return (     <ResponsiveContext.Provider value={{ windowWidth, isMobile, isTablet, isDesktop }}>       {children}     </ResponsiveContext.Provider>   ); };
    Wrap your application with <ResponsiveProvider> at the root level, and any component can access the responsive state using useContext(ResponsiveContext).
    Step 3: Add Media Queries to React Components
    Now that you’ve set up dynamic screen detection in Step 2, it’s time to apply media queries to style your React components. Whether you’re using traditional CSS files or CSS-in-JS libraries, media queries allow your components to adapt seamlessly to different screen sizes.
    Translating Design Breakpoints into Media Queries
    Design tools like Figma or Adobe XD often include specific breakpoints for layouts – such as 320px for mobile, 768px for tablets, and 1024px for desktops. Converting these breakpoints into media queries is essential for maintaining a cohesive and consistent design across your application.
    For traditional CSS, you can centralize your breakpoints and apply them in your stylesheets like this:
    .responsive-container {   width: 100%;   padding: 10px; }  @media (min-width: 768px) {   .responsive-container {     width: 80%;     padding: 20px;   } }  @media (min-width: 1024px) {   .responsive-container {     width: 60%;     padding: 30px;   } }
    This approach works well for projects with dedicated stylesheets, but it can lead to challenges when managing styles and behavior separately in CSS and JavaScript files.
    A more streamlined method for React applications involves keeping media queries close to your components. For example, you can define your breakpoints in a shared file and import them into your CSS modules:
    // breakpoints.js export const breakpoints = {   mobile: 320,   tablet: 768,   desktop: 1024,   largeDesktop: 1440, };  // styles.module.css .container {   width: 100%; }  @media (min-width: 768px) {   .container {     width: 80%;   } }
    This ensures your breakpoints remain consistent throughout the application and are easy to update.
    CSS-in-JS for Media Queries
    CSS-in-JS solutions bring your styles and components closer together, making your code easier to manage. Instead of maintaining separate stylesheets, you define styles directly within your component files.
    Here’s a simple example using styled-components:
    import styled from 'styled-components';  const ResponsiveDiv = styled.div`   background-color: lightblue;   padding: 10px;    @media (max-width: 600px) {     background-color: lightcoral;     padding: 5px;   } `;  const MyComponent = () => {   return <ResponsiveDiv>This div changes color on mobile</ResponsiveDiv>; };
    To make this even more efficient, you can use centralized breakpoints. Import them into your styled components and reference them directly:
    import styled from 'styled-components'; import { breakpoints } from './breakpoints';  const ResponsiveContainer = styled.div`   width: 100%;   padding: 10px;    @media (min-width: ${breakpoints.tablet}px) {     width: 80%;     padding: 20px;   }    @media (min-width: ${breakpoints.desktop}px) {     width: 60%;     padding: 30px;   } `;
    This approach ensures that any changes to your breakpoints propagate automatically across all components.
    For cleaner and more readable code, you can encapsulate your media query logic in a helper object:
    // mediaQueries.js import { breakpoints } from './breakpoints';  export const media = {   mobile: `@media (max-width: ${breakpoints.tablet - 1}px)`,   tablet: `@media (min-width: ${breakpoints.tablet}px) and (max-width: ${breakpoints.desktop - 1}px)`,   desktop: `@media (min-width: ${breakpoints.desktop}px)`,   largeDesktop: `@media (min-width: ${breakpoints.largeDesktop}px)`, };  // Usage in styled components import styled from 'styled-components'; import { media } from './mediaQueries';  const ResponsiveGrid = styled.div`   display: grid;   grid-template-columns: 1fr;   gap: 10px;    ${media.tablet} {     grid-template-columns: 1fr 1fr;     gap: 20px;   }    ${media.desktop} {     grid-template-columns: 1fr 1fr 1fr;     gap: 30px;   } `;
    This keeps your components clean and avoids repetitive media query definitions, making your code easier to maintain.
    CSS-in-JS also allows you to create dynamic styles based on component props, enabling even more responsive and flexible designs:
    const FlexContainer = styled.div`   display: flex;   flex-direction: ${props => props.isMobile ? 'column' : 'row'};   gap: ${props => props.isMobile ? '10px' : '20px'};    @media (min-width: ${breakpoints.tablet}px) {     flex-direction: row;     gap: 20px;   } `;  const MyComponent = () => {   const { isMobile } = useResponsive();    return (     <FlexContainer isMobile={isMobile}>       <div>Item 1</div>       <div>Item 2</div>     </FlexContainer>   ); };
    Using Utility-First Frameworks
    If you’re working with a utility-first framework like Tailwind CSS, media queries become even simpler. Tailwind includes predefined responsive prefixes like sm:, md:, and lg:, which you can directly apply in your JSX:
    const ResponsiveCard = () => {   return (     <div className="w-full md:w-1/2 lg:w-1/3 p-4 md:p-6 lg:p-8">       <h2 className="text-lg md:text-xl lg:text-2xl">Card Title</h2>       <p className="text-sm md:text-base">Card content goes here</p>     </div>   ); };
    This approach reduces custom CSS and keeps your responsive logic clear and readable.
    Testing Media Queries
    Always test your media queries on both emulators and real devices. Use browser DevTools to simulate various screen sizes, including small screens (320px) and ultra-wide displays (1920px or more). Real device testing is crucial for catching issues like touch interaction problems or unexpected rendering quirks.
    These practices, combined with tools like UXPin for interactive prototypes, ensure your components remain responsive and aligned with the design vision. Media queries bring your React components to life, allowing them to adapt beautifully to any screen size.
    Step 4: Build Reusable Responsive Components
    With your media queries and hooks in place, it’s time to create components that handle responsiveness effortlessly. The aim here is to build components that can seamlessly adapt to different screen sizes and be reused across your application.
    Create Responsive Container Components
    Container components form the backbone of responsive layouts. These components wrap other elements and adjust their layout, spacing, and styles automatically based on the screen size. For instance, using a responsive grid container simplifies this process. Instead of manually setting column counts for every breakpoint, you can leverage CSS Grid’s auto-fit and minmax() to create a layout that adjusts itself dynamically:
    import React from 'react'; import './ResponsiveGrid.css';  const ResponsiveGridContainer = ({ children, gap = '16px' }) => {   return (     <div className="grid-container" style={{ gap }}>       {children}     </div>   ); };  export default ResponsiveGridContainer;
    The CSS for this component ensures responsive behavior:
    .grid-container {   display: grid;   grid-template-columns: repeat(auto-fit, minmax(250px, 1fr));   gap: 16px;   padding: 20px; }  @media (max-width: 768px) {   .grid-container {     grid-template-columns: repeat(auto-fit, minmax(200px, 1fr));   } }  @media (max-width: 480px) {   .grid-container {     grid-template-columns: 1fr;   } }
    This approach eliminates the need for JavaScript to handle breakpoints, as the grid automatically adjusts based on available space.
    To add more customization, you can pass configuration props for breakpoints and column counts:
    const ResponsiveContainer = ({   children,   breakpoints = { mobile: 480, tablet: 768, desktop: 1024 },   columns = { mobile: 1, tablet: 2, desktop: 3 },   gap = '20px',   padding = '24px', }) => {   const { width } = useResponsive(breakpoints);    const getColumns = () => {     if (width < breakpoints.mobile) return columns.mobile;     if (width < breakpoints.tablet) return columns.tablet;     return columns.desktop;   };    return (     <div       style={{         display: 'grid',         gridTemplateColumns: `repeat(${getColumns()}, 1fr)`,         gap,         padding,       }}     >       {children}     </div>   ); };
    You can also implement a spacing system that adapts to different breakpoints, ensuring a consistent visual hierarchy across devices:
    const useResponsiveSpacing = () => {   const { isMobile, isTablet } = useResponsive();    return {     xs: isMobile ? '8px' : isTablet ? '12px' : '16px',     sm: isMobile ? '12px' : isTablet ? '16px' : '20px',     md: isMobile ? '16px' : isTablet ? '20px' : '24px',     lg: isMobile ? '20px' : isTablet ? '24px' : '32px',     fontSize: {       small: isMobile ? '12px' : '14px',       base: isMobile ? '14px' : '16px',       large: isMobile ? '18px' : '20px',     },   }; };
    When designing responsive containers, keep these principles in mind:
    • Flexibility: Use relative units like percentages or rem instead of fixed pixels.
    • Breakpoint Awareness: Adjust layouts based on predefined screen size thresholds.
    • Reusability: Encapsulate responsive logic so components can adapt to multiple contexts.
    Extract Responsive Logic into Custom Hooks
    Custom hooks are a great way to keep your responsive components clean and maintainable. By centralizing screen size detection and breakpoint logic into hooks, you can simplify your components and make your codebase easier to manage.
    For example, you can use or extend the useResponsive hook to handle screen size detection. The typeof window !== 'undefined' check ensures compatibility with server-side rendering.
    This hook can then be used to conditionally render layout variations:
    const ResponsiveCard = ({ title, content }) => {   const { isMobile, isTablet } = useResponsive();    const cardStyle = {     padding: isMobile ? '16px' : '24px',     fontSize: isMobile ? '14px' : '16px',     maxWidth: isMobile ? '100%' : isTablet ? '80%' : '60%',     margin: '0 auto',   };    return (     <div style={cardStyle}>       <h2>{title}</h2>       <p>{content}</p>     </div>   ); };
    Custom hooks also enable you to render entirely different components based on the device:
    const Dashboard = () => {   const { isMobile } = useResponsive();    return (     <div>       {isMobile ? <MobileDashboard /> : <DesktopDashboard />}     </div>   ); };
    React’s component-based structure makes it simple to build responsive applications. Components can be reused and rearranged for different screen sizes, ensuring consistent behavior throughout your app.
    For an even cleaner API, consider using responsive props. Instead of passing multiple props for various screen sizes, use a single object that defines how the component should behave at each breakpoint:
    <Card   responsive={{     mobile: { columns: 1, padding: '16px' },     tablet: { columns: 2, padding: '20px' },     desktop: { columns: 3, padding: '24px' },   }} />
    Step 5: Test Your Responsive Design
    Testing is the backbone of ensuring your responsive React components work seamlessly across different devices and environments. Even the most carefully crafted components can behave unpredictably at certain breakpoints, so thorough testing helps catch these quirks before users encounter them.
    Test with Browser DevTools
    Browser DevTools are your go-to tools for testing responsive designs without needing physical devices. By activating Device Emulation mode, you can simulate different device viewports. This feature comes with predefined options for devices like the iPhone 12, iPad Pro, and a variety of Android phones. These presets make it easier to check how your components behave across a range of screen sizes. You can also manually adjust the viewport dimensions to test specific breakpoints defined in your code.
    For example, if your layout shifts from one column to two at 768px, test at 767px and 769px to ensure the transition happens smoothly. This method helps you catch edge cases where layouts might break or behave oddly.
    Use the Inspector and Layout panels in DevTools to confirm that your media queries are being applied correctly and that your grid or flexbox layouts behave as expected. You can toggle media query conditions on and off to see how styles adapt in real time.
    Expand your testing to cover screen widths from 320px to 2560px and check both portrait and landscape orientations. DevTools also let you simulate different network speeds (like 3G or LTE) and monitor performance metrics such as frame rates, CPU usage, and rendering times. Tools like Lighthouse can offer additional insights into performance bottlenecks.
    Some common issues to watch for include content overflow, unexpected layout shifts, and inconsistent spacing across breakpoints. These problems can often be addressed by using responsive spacing techniques, like CSS variables or styled-components. Also, ensure interactive elements like buttons meet accessibility standards, with touch targets no smaller than 44×44 pixels.
    Once you’re satisfied with your DevTools testing, move on to real devices for a final validation step.
    Test on Real Devices
    While emulators are a great starting point, real-device testing is essential for capturing the nuances of actual user interactions. Emulators can’t always replicate hardware behavior, network conditions, or touch inputs perfectly. Testing on a range of real devices – including iOS and Android smartphones, tablets, and desktops – provides a more accurate picture of how your components perform.
    If your access to physical devices is limited, cloud-based platforms like BrowserStack can give you remote access to thousands of devices. These platforms are especially helpful for testing on hardware you don’t own. The React DevTools browser extension is another useful resource for inspecting your app’s components during real-device testing.
    Pay close attention to key interactions like touch input, scrolling, and how layouts adapt when switching between portrait and landscape modes. Performance testing is particularly important on lower-end devices, as they may struggle with components that perform well in emulated environments. Check for smooth load times, animations, and scrolling behavior.
    Document your testing process in a matrix that outlines the devices and breakpoints you’ve tested, along with screenshots or videos showcasing responsive behavior. This documentation not only helps communicate issues to your team but also serves as a reference to prevent regressions in future updates.
    "As a full stack design team, UXPin Merge is our primary tool when designing user experiences. We have fully integrated our custom-built React Design System and can design with our coded components. It has increased our productivity, quality, and consistency, streamlining our testing of layouts and the developer handoff process." – Brian Demchak, Sr. UX Designer at AAA Digital & Creative Services
    When issues arise, create detailed bug reports. Include the viewport size where the problem occurs, the expected behavior, the actual behavior observed, and steps to reproduce the issue. For instance: "At 375px width (iPhone SE), the navigation menu overlaps the hero image instead of stacking below it." Use tools like Jira or GitHub Issues to log these problems and assign appropriate severity levels for resolution.
    Automating responsive design simplifies adapting your application for multiple devices. By following the five steps outlined here – setting up your React environment, using hooks to detect screen size, implementing media queries, creating reusable components, and thoroughly testing – you can build a system that minimizes repetitive manual adjustments while ensuring consistent breakpoints across your project.
    The secret to making this process efficient is centralizing your responsive logic. By using custom hooks for screen size detection and defining breakpoints in a single configuration file, you create a unified source of truth. This not only reduces redundant code but also makes updates seamless – adjusting a breakpoint in one place updates it across your entire application automatically.
    React’s component-based structure naturally supports automation for responsive design. Instead of simply hiding elements with CSS, you can conditionally render entire component trees based on screen size, improving both load times and performance on mobile devices. Pairing this with CSS-in-JS solutions allows you to colocate styles with your component logic while still leveraging the flexibility of traditional media queries.
    Tools like UXPin further enhance this workflow by bridging the gap between design and development. Designers can use actual React components to build prototypes, ensuring that responsive behaviors are validated early in the process. These prototypes can then be transitioned seamlessly into production code. With support for popular libraries like Material-UI and Tailwind UI, as well as syncing with custom Git repositories, UXPin ensures that design and development stay aligned from start to finish. This streamlined design-to-code workflow helps eliminate manual adjustments and ensures consistency throughout the entire development cycle.
    What’s the best way to test responsive React components on various devices and environments?
    To thoroughly test responsive React components, it’s important to use a mix of tools and strategies. Start with browser developer tools to simulate different screen sizes and resolutions. This is a quick way to see how your components adjust for devices like smartphones, tablets, and desktops.
    For a deeper dive, test on physical devices or use device farms to check how your components perform in real-world conditions. On top of that, automate your testing process with tools like Jest or React Testing Library. These tools can help confirm that your components behave as expected when the viewport size or orientation changes. By combining these approaches, you can ensure your components deliver a smooth experience across all devices.
    What are the advantages of using CSS-in-JS tools like styled-components for responsive design in React?
    CSS-in-JS tools like styled-components bring a lot to the table when it comes to handling responsive design in React applications. They let you write CSS right inside your JavaScript, which means you can tweak styles dynamically based on props, state, or other variables. This flexibility makes it much simpler to create designs that adapt seamlessly to different screen sizes or user interactions.
    One of the standout perks is how these tools scope styles specifically to individual components. This eliminates the hassle of style conflicts and helps keep your codebase more organized and easier to maintain. Plus, with built-in features like theme management and smooth media query integration, CSS-in-JS solutions make building consistent and responsive designs across your app a whole lot easier.
    How can I improve the performance of React components when handling frequent window resize events?
    To improve the performance of React components during frequent window resize events, you can rely on techniques like debouncing and throttling. These approaches minimize the number of resize event calls, reducing unnecessary re-renders and enhancing overall efficiency.
    Using React hooks like useEffect and useState can also make state management smoother. For instance, you can set up a resize event listener inside a useEffect hook and ensure proper cleanup when the component unmounts. This prevents memory leaks and keeps your app running efficiently.
    For more complex scenarios, libraries such as lodash or resize-observer-polyfill can simplify event handling and further optimize performance. These tools are especially helpful when you need more robust solutions for managing resize events.
