UXPin Changelog June 2018 #9
Paweł Wakuła
By Paweł Wakuła on 3rd July, 2018 Updated on 15th August, 2021
In June, we’ve released many features to improve the workflow in UXPin Editor and build better high fidelity prototypes. Details below.
Editor and Preview
  • [New] Redesigned properties panel split into separate styling sections.
  • [New] Context top bar menu – allows to group and ungroup the  elements, turn them into symbols and open the interactions panel quickly.Context top menu bar
  • [New] Blending modes – allow to determine how two layers are interacting with each other.
  • [New] Spread support for shadows – helps control shadow contour.Spread support for shadows UXPin
  • [New]  Shortcuts for elements distribution: vertical (cmd/ctrl+alt+Y) and horizontal(cmd/ctrl+alt+X).
  • [Improved] Show/hide elements is now available in the layers section in properties panel.
  • [Improved] Improved way of managing elements in layers depending if you click or double-click on the element.
  • [Improved] Dragging with cmd/ctrl pressed selects only elements entirely in selection bounds.
  • [Improved] Disable snapping with a key (cmd) modificator.
  • [Improved] Reorganised and shrank right-click menu in the Editor.
  • [Improved] Zoom control has been moved back to the top bar.
  • [Improved] Locked elements are selectable from the layers panel only.
Pen tool improvements
  • [New] Added 10 different types of endpoints for a path to create different arrows.Different paths for arrows
  • [New] Set the shape of ends and joins for any path.set shape fo ends and joints
  • [New] Set dashed line – allows to decide whether a path should be solid, dashed or dotted with precise control of each dash and gap length.Set dashed line UXPin
  • [New] Added start/stop options for stroke.
  • [New] Set the position of each path node directly from properties panel.
Design Systems
  • [Improved] Select the whole image and then delete it with backspace
  • Small bug fixes and visual improvements.
If you’re interested what we released in May, please check out Changelog 2018 #8.
Sign up for a free trial.
