Managing color consistency in a design system is crucial for usability, trust, and accessibility. When colors are inconsistent, users face confusion, accessibility suffers, and brand identity weakens. Here’s how to tackle it effectively:
- Why It Matters: Consistent colors build trust, align expectations, and improve accessibility. For instance, red should signal errors, not mix with emphasis.
- Challenges: Common issues include too many similar shades (color bloat), mismatched technical formats (HEX, RGB), unclear naming conventions, and accessibility oversights.
- Solution: Use semantic color tokens – organizing colors by purpose (e.g.,
action-primary, notblue-500) – to streamline updates and ensure consistency across platforms. - Best Practices: Avoid ambiguous names, separate brand and functional colors, and ensure accessibility by meeting WCAG contrast standards (e.g., 4.5:1 for normal text).
- Tools: Leverage design systems like UXPin for centralized token management, contrast checks, and seamless design-to-development workflows.
In short, a structured approach to color management ensures clarity, accessibility, and a stronger brand presence.
Design Tokens for Dummies | A Complete Guide
Creating a Semantic Color Token System
Three-Layer Color Token System: Primitive, Semantic, and Component Tokens
Tame the chaos of inconsistent color usage with semantic color tokens – a method that organizes colors based on their purpose, not their appearance. Instead of naming a color something like blue-500 or #007AFF, you’d use names like action-primary or text-error. This approach establishes a shared language between designers and developers, making it easier to scale and maintain.
Understanding Color Tokens
Color tokens are layered to serve different roles. At the base, you have primitive tokens (also known as base or global tokens). These represent the raw color values, such as HEX or RGB codes like blue-500 or neutral-200. Think of these as the building blocks of your palette. Above them are semantic tokens, which describe the intent behind the color, such as background-surface-critical or text-subtle. These semantic tokens act as aliases that point to primitive values, creating a flexible and adaptable system.
This structure makes updates seamless. For instance, if you switch your primary brand color from purple-500 to green-600, you only need to update the primitive token. All linked semantic tokens, such as action-primary, will automatically reflect the change. This is especially helpful for teams managing multiple themes. A semantic token like background-surface can map to white in light mode and dark gray in dark mode, eliminating redundant code.
| Token Type | Example | Purpose | Value |
| Primitive | blue-500 |
Defines a specific color in the palette | HEX/RGB |
| Semantic | action-primary |
Describes intent (e.g., primary buttons) | Alias to Primitive |
| Component | button-bg-hover |
Defines a specific state for a component | Alias to Semantic |
"Color roles are designed to express your brand and support light and dark themes. They help ensure visual coherence without hardcoding." – Material Design 3
By using clear, functional names, you can fully leverage the power of semantic tokens while avoiding confusion.
Best Practices for Naming Conventions
Avoid value-based names. Labels like blue-100 or dark-red don’t convey a color’s purpose. Instead, use names like color-error-text or color-success-bg that clearly communicate intent. This eliminates guesswork for developers, ensuring they know exactly where and how to use a token.
For primitive tokens, adopt a numeric scale from 50 to 950. Typically, 500 represents the primary brand color, while lower numbers (50–400) are lighter tints, and higher numbers (600–950) are darker shades. This standardized range simplifies the process of selecting shades. You can also use half-steps like 50 or 950 to fine-tune contrasts, especially in dark mode.
Keep brand colors and functional colors separate. Brand tokens express your identity and evoke emotion, while functional tokens handle usability signals like errors, warnings, or success states. Mixing these can confuse users – for example, using the same shade of red for your brand and for error messages sends conflicting signals.
Building Scalable and Accessible Color Palettes
Creating Color Scales
To create a scalable color palette, you can use HSL adjustments to generate consistent tints and shades. Aim for scales with 10–15 steps (e.g., 100–1100) to cover a variety of needs like backgrounds, interactive states, and high-contrast text. In many systems, the 700 weight is often used as the base for primary UI elements because it typically meets the 4.5:1 contrast ratio required for accessibility on light backgrounds. Lighter tints (100–400) work well for backgrounds and subtle elements, while darker shades (600–950) are better suited for text and areas that need emphasis.
A great example of this approach is Lyft’s open-source tool, Colorbox. It uses algorithms based on hue, saturation, and brightness curves to create scalable and accessible color systems with mathematical precision. Another method is gradient mapping – creating a gradient between the darkest and lightest versions of your brand color and dividing it into 9–11 equal segments to ensure consistency.
For better organization, divide your palette into functional categories:
- Primary: Your brand’s main colors.
- Secondary: Complementary colors.
- Neutrals: Grays for text and backgrounds.
- Semantic: Colors for specific states like success, error, or warnings.
For instance, Atlassian‘s Design System uses a structured neutral palette (N0 to N900), assigning specific ranges for backgrounds (N0–N10), interactive elements (N20–N50), and typography (N500–N900). Thoughtfully crafted color scales like these help meet accessibility requirements while maintaining visual clarity.
Meeting Accessibility Standards
Accessibility is key when designing color palettes. According to WCAG 2.0 Level AA guidelines, normal text must have a contrast ratio of at least 4.5:1, while large text requires a minimum of 3:1. These standards ensure that digital interfaces remain usable for everyone, including the 4.5% of the population with some form of color blindness. Red-green color blindness, the most common type, affects about 8% of adult men and 0.5% of adult women.
"Color should only be used as progressive enhancement – if color is the only signal, that signal won’t get through as intended to everyone." – U.S. Web Design System (USWDS)
To ensure your colors meet these standards, use tools like the WebAIM Contrast Checker, Stark for Figma, or Color Oracle to simulate color blindness and validate your choices in real time. Documenting pre-approved color combinations in a contrast pairs matrix – such as "Primary Blue on White" – can help avoid inaccessible pairings in your designs.
It’s also important not to rely on color alone. Supplement your designs with icons, text labels, or patterns to assist users with color vision deficiencies. For example, an error state should include not just red coloring but also an error icon and descriptive text. A helpful practice is to design your UI hierarchy in grayscale first. If the layout and messaging aren’t clear without color, adding color won’t fix the problem.
| Accessibility Level | Normal Text Contrast | Large Text Contrast |
| WCAG AA | 4.5:1 | 3:1 |
| WCAG AAA | 7:1 | 4.5:1 |
| UI Components | 3:1 | 3:1 |
How UXPin Helps Maintain Color Consistency
UXPin simplifies the challenge of maintaining consistent colors across design and development by building on scalable, accessible color palettes.
Code-Backed Prototypes with UXPin
With UXPin’s code-backed prototyping, design colors seamlessly align with production by leveraging actual React components.
"With Merge, designers and engineers work on the same, fully functional UI elements and patterns in the exact same repository." – UXPin
In the "Get Code" mode, developers can see each token’s name and HEX value, which eliminates any confusion during handoff. For example, tokens like Background-primary-button provide clear references, ensuring smooth collaboration. This system fosters precise token management, making design-to-development workflows more efficient.
Using Design Tokens in UXPin
UXPin tackles common challenges like color inconsistencies and technical silos with its centralized token system. This system consolidates color properties into reusable design tokens.
These tokens support multiple formats, including HEX, RGB, and RGBA, ensuring compatibility across platforms. When a color update is needed, the Token Update modal allows users to compare the before-and-after states, ensuring changes are deliberate and well-controlled across projects. For those wanting to test new styles without altering the entire system, the "Detach token" feature lets you override an element with a specific HEX value.
Color tokens also integrate directly with UXPin Merge components through attributes like @uxpincontroltype color. This lets designers apply approved system tokens to coded elements via a color picker. By doing so, UXPin establishes a single source of truth, preventing "color drift" – a common issue when teams unintentionally use slightly different shades of a brand color.
Keeping colors consistent isn’t just about aesthetics – it builds trust, improves usability, and makes workflows more efficient. By using a centralized system with semantic tokens, you can cut through the clutter of redundant color values and establish a single source of truth that aligns designers and developers.
Adopting functional naming conventions and integrating design with code has made color management simpler and more reliable. This method saves time, minimizes mistakes, and ensures your brand remains consistent across every platform and interaction.
Tools like UXPin offer automated documentation, token management, and seamless code integration to maintain consistency. They help ensure that the colors defined in your design system are exactly what users see in the final product, eliminating any chance of "color drift."
What are semantic color tokens, and how do they help maintain color consistency in design systems?
Semantic color tokens are variables in a design system that represent the function or purpose of a color, rather than its exact value (like HEX or RGB). For instance, instead of assigning a specific color code like #1E90FF to a button, you’d use a token such as color.primary or color.success. These tokens convey the intent behind the color – whether it’s for a primary action, a success message, or something else. What’s more, these tokens are linked to base colors, making it easy to adapt them to different themes, like light and dark modes.
This separation of purpose from value ensures uniform color application across components and platforms. If a brand decides to update its primary color, designers only need to adjust the base token. The entire system then updates automatically, saving time, reducing mistakes, and keeping elements like buttons, text, and icons aligned with the design’s overall intent. Tools like UXPin help teams define and apply these semantic color tokens directly into their design libraries, making updates seamless and ensuring consistency across the brand.
How can design systems maintain accessible and consistent color usage?
To ensure colors in your design remain accessible and consistent, it’s essential to establish a carefully curated palette that complies with WCAG AA or AAA contrast standards. This means selecting colors that provide adequate contrast for text, icons, and interactive elements, making content easier to perceive for users with low vision or color blindness. For instance, normal text should achieve a contrast ratio of at least 4.5:1, while larger text can meet a minimum ratio of 3:1.
Adopting color tokens instead of hard-coded color values is a smart way to maintain both consistency and accessibility. Think of tokens as a centralized reference for colors, such as color.textPrimary or color.bgSurface, which are pre-tested for contrast compliance. When a token is updated, the changes automatically apply to all related components, minimizing errors and ensuring accessibility across the board.
To make designs even more inclusive, consider offering both light and dark mode options, avoid using color alone to communicate critical information, and use clear, semantic naming for tokens to improve clarity and usability.
Platforms like UXPin’s Color Tokens feature simplify managing and auditing these color libraries directly within your design system. This allows teams to ensure compliance with accessibility guidelines while streamlining updates efficiently.
Why should brand and functional colors be kept separate in a design system?
Separating brand colors from functional colors is a smart way to maintain clarity and adaptability within a design system. Brand colors – like your primary, secondary, and accent shades – are all about representing your company’s identity. They create a consistent, recognizable look across everything from marketing materials to product interfaces. Keeping these colors distinct helps preserve their visual and emotional impact.
On the flip side, functional colors serve a completely different purpose. These are the hues used for things like error messages, success notifications, or data visualizations. They need to meet strict accessibility standards and stay consistent across all UI components. By keeping functional colors separate from brand colors, you make it easier to tweak these specific hues without accidentally affecting your brand’s overall look. This separation also streamlines workflows, letting designers and developers manage and update colors independently. The result? Smoother teamwork and better scalability for your products.
In practice, this approach clears up confusion, speeds up onboarding for new team members, and simplifies updates during brand refreshes or accessibility improvements. It’s a win-win for maintaining the strength of both your brand identity and your functional UI elements.
