Claude Design vs UXPin Forge: What Enterprise Teams Need to Know
By Andrew Martin on 20th April, 2026
    On April 17, 2026, Anthropic launched Claude Design. Figma’s stock dropped 7% the same day. The design community split into two camps: one declaring the end of design tools as we know them, the other dismissing it as overhyped AI slop.
    Both camps are wrong. Claude Design is a genuinely useful tool that solves a real problem for a specific audience. It is also architecturally incapable of solving the problem enterprise design system teams face.
    Understanding which problem you have determines which tool matters to you. This article breaks down the difference.
    What Claude Design actually does
    Claude Design is a conversational visual creation tool inside Claude.ai. You describe what you need in plain language, and Claude generates it on a live canvas. Prototypes, pitch decks, landing pages, one-pagers, marketing materials.
    The tool can read your codebase and design files to extract visual patterns – colours, typography, spacing – and apply them to everything it generates. You refine through conversation, inline comments, direct edits, and custom sliders. When you’re done, you export to Canva, PDF, PPTX, HTML, or hand off to Claude Code for implementation.
    It’s powered by Claude Opus 4.7 and available as a research preview for paid Claude subscribers.
    For founders, product managers, and marketers who need to get from an idea to something visual quickly, Claude Design is excellent. It’s fast, the output is aesthetically strong, and it democratises visual creation for people who were never going to open Figma.
    That’s genuine praise. We tested it ourselves over the weekend.
    Three issues that show up in practice
    After testing Claude Design and reading hundreds of reactions from designers, developers, and product teams, three consistent problems emerged.
    It approximates your design system. It doesn’t use it.
    Claude Design reads your codebase and extracts visual patterns. It generates new elements styled to match those patterns. That’s useful for quick visuals. But it’s fundamentally different from using your actual components.
    When Claude Design generates a button, it creates something that looks like your button. It doesn’t place your actual Button component with its real props, real variants, and real states. There’s no loading state, no disabled variant, no destructive option – unless the AI happens to guess that those exist.
    Multiple users reported design system drift during their first sessions: wrong fonts, incorrect button colours, inconsistent spacing. One designer spent more time fixing the AI’s mistakes than it would have taken to build from scratch.
    This isn’t a bug. It’s the architecture. When the AI interprets your codebase rather than being constrained to your component library, drift is inevitable. The more complex your design system, the faster it drifts.
    Reading a codebase gives you visuals that look like your product. Syncing a component library gives you the real thing.
    Every interaction costs tokens – including manual edits.
    Claude Design’s refinement tools (inline comments, direct edits, custom sliders) all route through the AI model. Every adjustment – including fine-grained tweaks to spacing, colour, and layout; all consumes credits.
    Users on the Max plan reported burning through their weekly token limit in 2-6 hours of active use. Several were locked out after a single complex prompt consumed 25% of their weekly allocation. One user generated 7 PowerPoint slides and used 25% of their weekly tokens before any refinement.
    The community quickly developed a mitigation strategy: use Opus 4.7 for the first prompt, switch to Sonnet for edits, and use Haiku for minor tweaks. That this strategy is necessary tells you something about the cost model.
    This creates what we’d call prompt lock-in: the AI is the only way to interact with your own design. Adjusting spacing shouldn’t require a round-trip to an LLM. It shouldn’t cost credits. It should be a design tool.
    The output still requires a handoff.
    Claude Design exports to Canva, PDF, PPTX, HTML, or hands off to Claude Code. The Claude Code handoff is positioned as a closed loop, but it’s still a translation step. Claude Code receives a design intent bundle and generates code from it. That code is not your component library – it’s new code generated to approximate the design.
    One UX designer put it directly: “I still need to actually finish building out the design system in code now.” After hours of design work in Claude Design, the production code still had to be written.
    For personal projects and MVPs, this workflow is fine. For enterprise teams shipping with existing codebases and component libraries, it’s the same gap that has always existed between design and production – just with a faster starting point.
    A fundamentally different architecture
    UXPin takes a different approach at the foundation level. The design canvas renders real production code. Your React component library syncs from Git or Storybook directly into the editor. When you place a Button on the canvas, it’s your actual Button component – same props, same variants, same code your developers ship.
    Forge, UXPin’s AI assistant, generates and iterates using these real components. It can’t drift from your design system because it can only use components that exist in your library. Off-brand output is structurally impossible.
    Here’s what that looks like in practice. This is real export output from UXPin:
    import Button from ‘@mui/material/Button’;import Card from ‘@mui/material/Card’;import TextField from ‘@mui/material/TextField’;import Typography from ‘@mui/material/Typography’;
    <Card >     <CardContent>          <Typography variant=”h5″>Create Account</Typography>          <TextField label=”Full Name” variant=”outlined” fullWidth />          <TextField label=”Email Address” type=”email” fullWidth />          <Button variant=”contained” fullWidth>Sign Up</Button>     </CardContent></Card>
    That’s not a spec. Not a screenshot with annotations. That’s production-ready React with real MUI imports, working state management, and event handlers. Developers copy it and ship it.
    After Forge generates, you switch to professional design tools on the same canvas. Layout adjustments, prop tweaks, variant exploration, responsive breakpoints, interaction design – all on the same code-backed components. No tokens consumed. No AI round-trip. Just design tools.
    AI handles the scaffold. Design tools handle the craft. No tokens burned on the last mile.
    How they compare
    Dimension Claude Design UXPin with Forge
    Design system input Reads codebase, extracts visual patterns Syncs component library via Git – renders actual components
    AI generates New elements styled to match Your actual components with real props
    Design system drift Reported frequently – wrong fonts, colours, spacing Structurally impossible – can only use what exists in library
    Manual refinement AI-routed – consumes tokens Professional design tools – no token cost
    Token usage 2-6 hours to hit weekly limit on Max plan AI credits for generation only; manual edits are free
    Code output Handoff to Claude Code for interpretation Production-ready JSX from your component library
    Post-gen design tools Inline comments, sliders (AI-powered) Full professional design suite (non-AI)
    AI models Opus 4.7 (single provider) GPT + Claude models, bring your own API key
    Ideal for Quick mockups, decks, visuals for non-designers Enterprise teams shipping with real design systems
    Who should use what
    Use Claude Design if:
    • You don’t have an existing design system or component library
    • You need quick mockups, pitch decks, or marketing visuals
    • You’re a founder, PM, or marketer who needs something visual without a design tool
    • You’re exploring ideas and don’t need production-ready output
    • You’re a solo developer or two-person team building from scratch
    Use UXPin with Forge if:
    • Your team has a custom React component library
    • Design system consistency and governance are requirements, not preferences
    • You need the AI output to be production-ready code, not a handoff bundle
    • Designers need real tools for refinement – not just a prompt box
    • You’re shipping production UI where what’s designed must be what’s deployed
    Use both if:
    • Your team uses Claude Design for early exploration and stakeholder communication, then UXPin for production design with real components. They solve different parts of the workflow.
    The real question Claude Design raises
    Claude Design isn’t a threat to tools that generate with real components. It’s a threat to tools whose only value is the AI model underneath.
    Anthropic is extending into every product category that runs on their model. If your tool’s entire value proposition is “prompt in, AI output out,” you’re building on infrastructure controlled by your biggest competitor. The AI model is their layer. They will always be better at it.
    The tools that survive this shift are the ones with value that exists independent of which model powers the AI. UXPin’s value is the component architecture – the Git sync, the real component rendering, the production code output. That existed before AI. Forge makes it faster, but the moat is the component layer, not the model layer.
    We already support both GPT and Claude models inside Forge. The model is interchangeable. The architecture isn’t.
    The question isn’t whether AI labs will enter your vertical. It’s whether your value survives when they do.
    What didn’t change
    Amid all the noise about stock drops and designer replacement, a few things remain true:
    AI generates the happy path. Every AI design tool produces clean, safe, slightly generic layouts. Error states, edge cases, empty states, loading sequences, accessibility considerations, the flow that handles the user who clicked the wrong thing twice – that’s still human judgment. AI gets you to 80%. The 20% where products succeed or fail is where design expertise lives.
    Good enough just raised the bar. More AI tools producing more average work doesn’t commoditise great design. It makes great design more visible by contrast. When everyone has access to “good enough,” the teams that invest in craft stand out more, not less.
    Design was never just the UI. As one designer put it: “If your workflow is ‘paste brief into Claude, accept output, ship it,’ you’re not designing – you’re gambling.” The real work is framing the right problem, validating with users, and collaborating across product and engineering. AI can’t prompt its way to that.
    We named our AI tool Forge for a reason. A forge doesn’t replace the blacksmith – it gives them heat and speed. The craft still requires human judgment. Claude Design reinforces that truth, not undermines it.
    Frequently asked questions
    What is the difference between Claude Design and UXPin Forge?
    Claude Design reads your codebase and generates visuals styled to match your brand. UXPin Forge syncs your actual React component library via Git and generates with the real production components. Claude Design approximates your design system. Forge is constrained to it.
    Does Claude Design use your actual components?
    No. Claude Design reads your codebase to extract visual patterns such as colours, typography, and spacing. It then generates new elements styled to match. It does not place your actual production components with their real props, variants, and states.
    Why does Claude Design output drift from your design system?
    Because it approximates rather than uses your components. Users report wrong fonts, incorrect button colours, and inconsistent spacing. This happens because the AI interprets your codebase rather than being constrained to your actual component library.
    Do manual edits in Claude Design consume tokens?
    Yes. Every interaction in Claude Design, including fine-grained adjustments like spacing and colour changes, requires a round-trip to the AI model and consumes credits. In UXPin, manual edits use standard design tools and do not consume AI credits.
    Which tool is better for enterprise design system teams?
    For enterprise teams with mature design systems, UXPin Forge is purpose-built. It syncs your production React component library, constrains AI output to your real components, provides professional design tools for refinement without token cost, and exports production-ready JSX. Claude Design is better suited for quick mockups, pitch decks, and visual exploration without an existing design system.
    Can I use both tools?
    Yes. Some teams use Claude Design for early exploration, stakeholder presentations, and quick visuals, then move to UXPin for production design with real components. They solve different parts of the workflow.
    See the difference for yourself
    The fastest way to understand the distinction is to try both. Generate a dashboard in Claude Design. Then generate the same dashboard in UXPin Forge with MUI, shadcn, Ant Design, or your own component library. Compare the output.
    We’ll be publishing side-by-side comparisons over the coming weeks. Follow along.
    Try Forge free: uxpin.com/forge
    Learn more about Merge: uxpin.com/merge
    by Andrew Martin on 20th April, 2026
