How to build UX using GPT-4.1 + Ant Design – Use UXPin Merge!
By Andrew Martin on 9th May, 2026
    Want to speed up your design-to-development process? Combining GPT-4.1, Ant Design, and UXPin Merge can reduce handoff time by up to 60% and cut rework by over 80%. This workflow lets you design with production-ready components, eliminating the need for developers to rebuild static mockups.
    Here’s how it works:
    • GPT-4.1 generates design ideas in seconds, tailored to your goals and users.
    • Ant Design provides 50+ pre-built, WCAG-compliant components for enterprise applications.
    • UXPin Merge syncs design files and code repositories, letting you export production-ready JSX code directly.
    With this approach, you can create interactive prototypes, test usability early, and deliver features in half the time. For example, a 4-week project can now be completed in just 2 weeks. Ready to transform your workflow? Let’s dive into the details.
    What You Need Before Starting
    To efficiently build code-backed UX, you’ll need three key things: a UXPin account with the right subscription plan, access to the Ant Design library, and the Forge AI assistant. The UXPin Growth plan ($69/month) or higher gives you direct access to GPT-4.1, Ant Design, and Forge. Meanwhile, the Core plan ($49/month) includes 200 AI credits for GPT-4.1, whereas the Growth plan or above grants access to the full Ant Design library and 500 credits.
    UXPin brings together GPT-4.1, Ant Design components, and Forge in one place. Once you sign up, you can start designing with production-ready code components and AI support right away.
    It’s worth noting that this workflow is built around component-based design. If you’re used to working with static mockups, you’ll need to adapt to working directly with coded elements like buttons, forms, and tables. As Andrew Martin from UXPin puts it:
    "When Forge generates a button, it places YOUR actual Button component: same props, same variants, same code your developers ship".
    This shift may take some getting used to, but the payoff is huge – eliminating the need for translating designs into code. Once your account and tools are set up, you can configure Ant Design components for immediate use.
    How to Set Up Ant Design Components
    Ant Design
    On the Growth plan or higher, UXPin includes Ant Design as a built-in library, letting you drag and drop React-based components directly onto your canvas. These aren’t just placeholders – they’re the actual production components, complete with the same props, variants, and states your developers use.
    If your team uses a customized or branded version of Ant Design, UXPin Merge allows you to sync your production code components from Git repositories or Storybook. This ensures that your designs reflect your specific brand rather than default components. Prototypes can then be exported as production-ready JSX code, built with your Ant Design components.
    Once Ant Design is configured, you can enable AI integration to leverage GPT-4.1 through Forge.
    How to Access GPT-4.1 Through Forge
    GPT-4.1
    Forge, UXPin’s AI assistant, works differently from standalone AI tools. It generates designs exclusively using approved design system components, ensuring that every layout is development-ready.
    To access GPT-4.1 through Forge, enable AI features in your UXPin account settings. Once activated, you can use Forge directly within the design canvas to generate layouts with real Ant Design components. For instance, instead of manually adding form fields and buttons, you could prompt: “Create a checkout flow with billing address fields and a payment summary.” Forge will then generate the page using actual Ant Design components, which you can tweak as needed.
    As of February 2026, UXPin enhanced Forge by adding newer models like Claude Sonnet 4.6 alongside GPT-4.1. These updates improve how Forge follows instructions and reduce the number of adjustments needed to finalize your design.
    How to Build UX with GPT-4.1, Ant Design, and UXPin Merge
    4-Step UXPin Merge Workflow: From GPT-4.1 Concept to Production Code
    After setting up your account and enabling Forge, you’re ready to create UX designs using production-ready components. This process blends AI-generated layouts with manual adjustments, giving you both speed and creative control. Start by generating your design concept, refine it as needed, and bring it to life with animations and interactivity.
    Step 1: Generate Design Concepts with GPT-4.1
    Begin by opening a new project in UXPin and activating Forge from the toolbar. Enter a descriptive prompt, such as: "Design a user dashboard with a navigation bar, data table, and filter options." Forge will use Ant Design components to generate a layout based on your input.
    The AI works directly with your approved design system. If the initial result doesn’t meet your needs, tweak your prompt or ask Forge to modify specific sections. This ensures the output aligns with your design standards.
    Step 2: Customize Components in the UXPin Canvas
    Once Forge creates the layout, switch to manual editing in the UXPin canvas. Select any component to access its properties in the panel on the right. Here, you’ll find the same React component properties used in production.
    "Forge generates UI with your real React components. Then you refine it with UXPin’s professional design tools on the same canvas, on the same components. Toggle between AI and manual editing anytime." – Andrew Martin, UXPin
    You can adjust spacing, typography, alignment, and more directly in this panel. These edits ensure your design is perfectly aligned with production standards.
    Step 3: Build Interactive Prototypes with Ant Design
    Once your layout is polished, it’s time to add interactivity. Use the Interactions menu to introduce conditional logic, variables, and expressions. For instance, you can configure a form button to display a loading spinner after submission or set fields to trigger state changes when filled.
    The best part? No coding is required. UXPin allows you to visually handle the logic, define multiple component states (like hover, active, or disabled), and test user flows. This lets you validate your designs with stakeholders and identify usability issues early.
    Step 4: Export Production-Ready Code
    After finalizing your prototype, export it as JSX code ready for integration. Since you’re working with real Ant Design components, the exported code seamlessly matches your production environment. Developers can incorporate this directly into the codebase, removing the usual friction of design-to-development handoffs. This streamlined workflow bridges the gap between design and code, ensuring consistency and efficiency.
    Benefits of Using GPT-4.1 and Ant Design with UXPin Merge
    This workflow improves design quality while speeding up the delivery process. By addressing common friction points, it fosters smoother collaboration between design and development, creating a more efficient design-to-development pipeline.
    Better Design-Development Alignment
    When you design using real Ant Design components, you’re working directly with the same code developers will use. This eliminates the risk of losing or misinterpreting details during handoffs. UXPin’s Spec Mode takes things a step further by automatically generating specifications, assets, and code snippets. This removes the need for manual documentation, which traditionally slows down collaboration between designers and developers. Unlike image-based tools that require developers to rebuild designs from scratch, DreamFactory and UXPin Merge both connect directly to your Git repository, ensuring that AI-driven design suggestions are always consistent with production code.
    AI That Follows Your Design System
    Forge ensures that layouts are created using only the components your team has already built and tested. This guarantees that every design aligns with your design system, reducing the need for revisions. A survey of 3,157 companies revealed that 69% are either using or developing a design system, highlighting the importance of AI tools that respect these frameworks.
    Faster Product Delivery
    By skipping the manual sketching phase, you can export code that developers can use right away. This reduces the back-and-forth often required during refinements and accelerates the journey from design to deployment. Features like advanced interactions – including form validation and data manipulation – can be tested early during prototyping. This approach helps identify usability issues before development starts, reflecting the growing industry trend toward code-based prototyping and closer collaboration between design and development.
    By combining GPT-4.1, Ant Design, and UXPin Merge, teams can eliminate the usual friction between design and development. Starting with ready-to-ship React components removes the need for a translation layer, ensuring that what’s designed is exactly what gets delivered.
    The advantages are clear. Teams adopting this approach report 35–50% faster MVP delivery. For instance, a fintech client was able to prototype a user dashboard in just 2 days instead of 10. AI-driven design concepts from GPT-4.1 via Forge speed up ideation by 50–70% compared to manual sketching. Additionally, using UXPin Merge with Ant Design reduces 80% of the errors typically seen in traditional handoffs.
    Key Takeaways
    This workflow tackles the core obstacles that slow down product teams. GPT-4.1 generates UI concepts that align with Ant Design components, ensuring full system compliance. Meanwhile, UXPin Merge exports production-ready code, so developers can implement designs without any reinterpretation. The results? Teams achieve 95% consistency scores across prototypes, compared to just 65% in disconnected workflows.
    Take this example: a SaaS company created an admin panel prototype in 4 hours using GPT-4.1 ideas and Ant Design components in UXPin. They then deployed the exported code within the same week – a process that previously took 3 weeks.
    Getting Started with UXPin Merge
    Ready to experience these benefits? With UXPin Merge, you can start without any coding experience. Sign up for a UXPin free trial to access the Ant Design library directly from the Merge catalog – no importing required. Use GPT-4.1 through Forge (built right into UXPin, no extra AI subscription needed) to prompt ideas like: "Suggest Ant Design components for a responsive e-commerce checkout." Customize the AI suggestions in the UXPin Canvas, build interactive prototypes, and export React code for your developers. Start with UXPin’s Ant Design template project, and you could have a working prototype in just 15–30 minutes.
    Do I need developers to set up Ant Design in UXPin Merge?
    Developers don’t need to handle the setup of Ant Design in UXPin Merge. With UXPin, you can work directly with real React components without writing code or dealing with a complicated setup. The process is streamlined, using tools like GPT-4.1 to create components, importing Ant Design components, and syncing them into UXPin Merge for seamless prototyping and testing – all without requiring extra effort from developers.
    How do I use my team’s customized Ant Design components in UXPin?
    Your team’s customized Ant Design components can seamlessly integrate into UXPin through UXPin Merge. By connecting your component library or code repository to UXPin, you can sync these components and use them directly in your prototypes. This approach keeps your team’s custom styles, behaviors, and configurations intact while ensuring real-time synchronization with your development environment for consistent functionality and design.
    What does the JSX export include, and how close is it to production code?
    The JSX export delivers production-ready React components crafted by GPT-4.1. These components come fully functional, blending logic, visuals, and interactivity seamlessly. Designed to align closely with final production code, they reduce the need for significant modifications, allowing for quicker integration into live projects and simplifying the development workflow.
