How to build UX using GPT-5.2 + Ant Design – Use UXPin Merge!
By Andrew Martin on 24th April, 2026 Updated on 9th May, 2026
    Combining GPT-5.2, Ant Design, and UXPin Merge simplifies UX design by bridging the gap between designers and developers. Here’s how it works:
    • GPT-5.2 generates layouts using real, functional React components.
    • Ant Design ensures consistent, scalable enterprise-level UI elements.
    • UXPin Merge syncs prototypes directly with production code, eliminating the need for manual handoffs.
    This workflow skips static mockups, reduces engineering time by up to 50%, and speeds up feedback cycles. By using production-ready components from the start, teams can create, refine, and test designs faster, all while maintaining alignment with their design system. The result? Faster product delivery with fewer errors.
    What You Need to Get Started
    To create AI-powered UX designs using this workflow, you’ll need three key components: a UXPin account with Merge capability, access to Ant Design components, and GPT-5.2 via UXPin Forge. If you already have a UXPin account, these features are included – no extra subscriptions or imports required.
    This workflow skips static mockups entirely. Instead, it uses production-ready code components right from the start. The AI generates layouts with the same React components developers use in production. As Brian Demchak, Sr. UX Designer at AAA Digital & Creative Services, explains:
    "UXPin Merge is our primary tool when designing user experiences… It has increased our productivity, quality, and consistency."
    Here’s a breakdown of the essential elements you’ll need.
    What Is UXPin Merge?
    UXPin Merge bridges the gap between design and development by connecting your design canvas to production-ready code components. Instead of dealing with placeholders or mockups that need to be rebuilt later, you can design with actual React components – such as buttons, tables, and forms – that are ready for deployment.
    Ant Design is already integrated into UXPin, so you can easily select it from the built-in React libraries in the editor. If your team uses a custom component library, you can sync it by connecting your Git repository. This direct connection ensures that what you prototype is exactly what gets implemented, eliminating the need for translation between design and development. For teams managing complex backend integrations and data pipelines, DreamFactory provides a self-hosted platform that governs API access to any data source, making it easy to connect your design prototypes with enterprise data systems and backend services.
    What GPT-5.2 Can Do
    GPT-5.2
    GPT-5.2 powers UXPin Forge, the AI assistant built into the platform, and it’s included at no extra cost. This AI generates layouts using your selected component library. For instance, if you ask it to "create a data table with filters", it uses Ant Design’s actual table component instead of creating a placeholder.
    This approach ensures that every AI-generated element is functional, tested, and ready for development. You can also refine designs without starting from scratch. For example, you can tweak elements with commands like "make this denser" or "change the primary color to tertiary."
    GPT-5.2 is designed to produce more reliable outputs. It reduces hallucinations by 30% compared to earlier versions and achieves a 70.9% win or tie rate against industry professionals on knowledge-based tasks. This means fewer manual corrections and a smoother UX workflow.
    How to Set Up Ant Design
    Ant Design
    Setting up Ant Design in UXPin is simple. Just select it from the built-in React libraries in the editor – there’s no need for downloads or installations.
    Once selected, the AI Helper (Forge) automatically uses Ant Design components to generate layouts. You can also take advantage of the UXPin Prompt Library, which provides pre-optimized prompts for common design elements like navigation bars, dashboards, and forms. Have a sketch or a screenshot? Upload it directly, and the AI will analyze the structure and recreate it using Ant Design components with the Image-to-UI feature.
    This setup ensures your entire team works from the same component library, maintaining consistent design elements across the board. No more mismatched buttons or spacing issues between designers and developers.
    How to Build UX Using GPT-5.2, Ant Design, and UXPin Merge
    5-Step Workflow for Building UX with GPT-5.2, Ant Design, and UXPin Merge
    Here’s how you can create AI-powered, code-ready UX designs step by step. By connecting your component library, leveraging AI for layout generation, refining designs, testing prototypes, and exporting production-ready code, this workflow eliminates the traditional back-and-forth between designers and developers.
    Step 1: Connect Ant Design to UXPin Merge
    Begin by linking Ant Design to UXPin Merge. In the UXPin editor, click the AI button and select "Ant Design" from the global library. This allows you to start designing with real, functional components instantly.
    For teams using custom component libraries, the Enterprise plan offers the "Custom Library AI" feature, which lets you connect your Git repository.
    Integration Method Best For Key Requirement
    Standard OSS Library Quick prototyping with default Ant Design elements Select "Ant Design" in UXPin library settings
    Git Integration (Merge Enterprise) Teams with custom Ant Design systems Git repository and uxpin.config.js
    Merge AI 2.0 AI-generated layouts using Ant Design Use the AI Helper/Prompt Library within UXPin
    Once Ant Design is connected, you’re ready to generate layouts using GPT-5.2 through UXPin Forge.
    Step 2: Use GPT-5.2 Through UXPin Forge
    UXPin Forge
    With the integration set up, use UXPin Forge to generate layouts using GPT-5.2. For example, input a prompt like "create a dashboard with a data table and filters", and the AI will build it using Ant Design components – not placeholders or static visuals.
    The AI adheres to your design system’s rules. As UXPin highlights, "Merge AI generates with real components (MUI/Shadcn/Ant/React Bootstrap or yours)". You can also leverage the Image-to-UI feature by uploading a sketch or screenshot, which the AI will recreate with Ant Design components.
    To make this even easier, the UXPin Prompt Library offers pre-designed prompts for common UI patterns like navigation bars, dashboards, and forms. Once the layout is generated, you can further refine it.
    Step 3: Create and Customize Components
    After generating a layout, you can tweak it using natural language commands. For example, instead of manually adjusting spacing or colors, simply type "tighten table columns" or "swap primary to tertiary", and the AI will update the design accordingly. This ensures your work stays aligned with your design system.
    Additionally, you can incorporate variables, expressions, and conditional logic to simulate real-world user interactions. For instance, when building a form, validation states can be added to trigger error messages for invalid inputs. This makes your prototype behave like the final product, rather than just a static representation.
    This approach delivers a functional first draft that you can refine further, saving time on repetitive tasks and allowing you to focus on improving the user experience.
    Step 4: Test Your Prototype
    Once your design is ready, test it using production-ready components. Interact with your prototype to confirm that states, logic, and interactions function as intended.
    Add conditional interactions to simulate more complex user flows. For example, clicking a button could trigger different outcomes based on user input. This level of detail provides stakeholders with a realistic preview of the final product.
    Mark Figueiredo, Sr. UX Team Lead at T. Rowe Price, shared:
    Step 5: Export to Production Code
    Once you’ve validated your prototype, export it as production-ready React code. The exported code includes all necessary dependencies and can be opened in environments like StackBlitz or passed directly to developers for integration.
    Larry Sawyer, Lead UX Designer, emphasized:
    This streamlined process eliminates the need for manual redlining, spec documents, or endless email chains. The design is the code, and the code is the design – a seamless handoff from design to development.
    Best Practices for AI-Enhanced UX Workflows
    To fully harness the potential of GPT-5.2 and UXPin Merge, think of AI as your design collaborator, not a replacement. It’s about striking a balance: keeping control over your design system while letting AI handle the repetitive, time-consuming tasks. Here’s how to make it work.
    Stay Consistent with Your Design System
    When you link Ant Design – or your own custom library – to UXPin Forge, the AI generates layouts using real, production-ready components rather than static mockups. This ensures that every button, table, and form field aligns perfectly with your existing codebase. Many organizations use custom libraries with AI to maintain system governance. By basing AI outputs on your component library, you automatically integrate accessibility standards and design rules. As UXPin emphasizes:
    "AI should create interfaces you can actually ship – not just pretty pictures."
    This approach guarantees consistency and reliability in AI-assisted design workflows.
    Test and Validate Regularly
    Once your design system is consistent, testing becomes essential. Ensure that interactions, states, and logic work as expected. Test user flows, check conditional interactions, and verify that validation states trigger correctly. Because your prototypes use real components, they behave like the final product, making it easier to spot and fix issues early. Regular testing not only improves the accuracy of your designs but also fine-tunes how the AI interprets your prompts.
    Use UXPin Forge for Ongoing Improvements
    When a layout needs adjustments, there’s no need to start over. The AI Helper in UXPin Forge allows you to refine existing designs with simple commands like "make this denser" or "swap primary to tertiary." The AI updates coded components in place, preserving your previous work. For enterprise teams, connecting a Git repository enables further customization with organization-specific building blocks and design tokens.
    "This is the bridge to ‘AI that stays inside your design system’."
    Combining production-ready components with AI-driven design bridges the long-standing gap between design and development. Tools like GPT-5.2, Ant Design, and UXPin Merge simplify workflows, reducing manual coding efforts by 70% and shrinking prototype-to-code timelines from weeks to just days. This approach directly tackles the challenges of siloed teams and inconsistent handoffs, ensuring a smoother transition from design to development. By using AI exclusively with production-ready components, the need for translation between design and development is eliminated.
    These efficiencies enable teams to deliver scalable, enterprise-level solutions. UXPin Merge, for instance, centralizes version control and allows for component reuse, which supports growth without creating workflow bottlenecks. Teams have reported 40–70% faster time-to-market and a 30% drop in bugs thanks to consistent code exports. Some industry leaders have even achieved up to a 50% reduction in engineering time.
    This workflow doesn’t just save time – it generates measurable returns. Companies leveraging AI-assisted design systems have managed to scale up to 10 or more projects per month while increasing user satisfaction scores by 25%. The result is an AI-powered pipeline that accelerates time-to-market and drives revenue growth.
    How do I keep GPT-5.2 outputs aligned with my design system?
    Integrating GPT-5.2 with UXPin Merge is a smart way to maintain design consistency. This setup ensures that AI-generated layouts automatically adhere to your design standards by leveraging predefined component libraries, such as Ant Design.
    You can take it further by connecting custom libraries through Git or npm, allowing GPT-5.2 to produce outputs that align perfectly with your design tokens, styles, and components. This seamless connection keeps everything on-brand and cohesive.
    Can I use my own Ant Design-based components from Git in UXPin Merge?
    Yes, you can integrate Ant Design-based components into UXPin Merge using Git. UXPin Merge allows you to connect custom component libraries through Git or npm, enabling the use of production-ready React components directly from your repositories. This means you can effortlessly bring your Ant Design components into UXPin Merge, streamlining your design and development process.
    What should I validate before exporting a prototype to React code?
    Before exporting, double-check that your prototype meets all project requirements and stays consistent with your design system. Test for responsiveness, interactions, and functionality directly in UXPin Merge. Make sure every component connects to its production-ready counterpart, and verify that layouts, properties, and interactions work as expected. This process helps ensure the exported code aligns perfectly with your design, reducing the need for revisions later.
