Convert text or mockups into production-ready React prototypes with Claude Sonnet 4.5, Ant Design, and UXPin Merge for faster, consistent design-to-code handoffs.
How to prototype using Claude Sonnet 4.5 + Ant Design – Use UXPin Merge!
Turn text prompts into production-ready React prototypes with Claude Sonnet 4.5, shadcn/ui, and UXPin Merge—add interactivity and export clean React code.
AI-driven layouts combined with production-ready code components let teams build interactive prototypes that match production and accelerate delivery.
Create production-aligned prototypes with UXPin Merge and Claude Opus 4.5—sync custom React design systems, generate AI components, and export ready JSX.
Generate production-ready React Bootstrap components with AI and import them into your design system to build interactive prototypes and speed design-to-code.
Create production-ready prototypes using AI-generated layouts, Ant Design components, and UXPin Merge to align design with production code and speed development.
Build production-ready React prototypes by combining Claude Opus 4.5, shadcn/ui components, and UXPin Merge for faster design-to-code workflows.
Build production-ready interactive prototypes by combining Claude Opus 4.5, MUI, and UXPin Merge to close design-to-development gaps.
Create production-ready React prototypes fast by using GPT-4.1 with UXPin Merge to generate, refine, and export clean JSX from your design system.
Create production-ready Bootstrap prototypes with GPT-4.1 and UXPin Merge—generate React components, sync design tokens, test interactions, and export JSX for development.
Most AI design tools have a fundamental problem: they generate pixels, not components. You describe a UI, AI draws rectangles that look like buttons and cards and inputs. It’s impressive in demos. Then your engineers rebuild everything from scratch because none of it is connected to your actual component library. We built something different. Forge
Generate production-ready React prototypes with AI that creates code-backed components, real interactions, and seamless design-to-development handoffs.
Design with production-ready code components to eliminate handoffs, reduce errors, and accelerate product launches using code-based prototyping.
Code-backed design using production components that reduces engineering time, adds AI-driven layouts, and provides enterprise security for large teams.
Compare UXPin’s code-based design with visual-only tools—use real production components to cut handoffs, reduce errors, and scale design systems.
