Build interactive React prototypes with GPT-5 Mini, shadcn/ui, and UXPin Merge — AI-generated, production-ready components and exportable JSX.
How to prototype using GPT-5 Mini + shadcn/ui – Use UXPin Merge!
Combine GPT-5 Mini, MUI, and UXPin Merge to build code-backed interactive prototypes that align with production React components and speed design-to-dev handoff.
Build production-ready React prototypes faster using GPT-5.1 with UXPin Merge to generate real components, layouts, and interactivity from simple prompts.
AI-generated prototypes built from real code components remove handoffs and speed product development with interactive, production-ready interfaces.
Create production-ready React prototypes with AI prompts and real design-system components to speed design-to-development handoffs and ensure consistency.
Generate production-ready React prototypes with GPT-5.1, shadcn/ui, and UXPin Merge—create, customize, and add interactions without a separate handoff.
Use GPT-5.1 with MUI and UXPin Merge to generate production-ready React prototypes, refine designs with AI, and export clean JSX.
AI-driven prototyping that builds production-ready UI from your React components, removing handoffs and accelerating development.
Generate production-ready Bootstrap components with GPT-5.2 in UXPin Merge to build interactive, code-backed prototypes and speed design-to-dev.
Design with production-ready React components in UXPin Merge to build accurate, interactive prototypes, align design and development, and export JSX for handoff.
Design touch-first responsive interfaces with proper touch target sizes, thumb-friendly layouts, scalable typography, immediate feedback, and real-device testing.
Compare centralized, decentralized, and hybrid team models for scaling design systems, and learn governance, maintenance, and scalability trade-offs.
Real-time feedback in prototyping exposes usability issues early, speeds iterations, and aligns design with users via live testing, in-app comments and analytics.
Convert Figma designs into reusable React components with AI—speed UI creation while adding manual logic, accessibility, and design-system alignment.
Eliminate manual token syncing and component drift by automating updates, docs, and governance with AI-driven workflows that keep design and code aligned.
