Use Claude Opus 4.5 with Ant Design and UXPin Merge to create production-ready React UIs, align design and code, and speed deployment.
How to build UI using Claude Opus 4.5 + Ant Design – Use UXPin Merge!
Build production-ready UIs using AI-generated layouts and real components to skip handoffs and export code-ready prototypes.
Use AI to generate production-ready MUI React components, sync them with UXPin Merge, and prototype code-backed UIs faster.
Generate production-ready React UI components from prompts using GPT-4.1 and sync them to your design system with UXPin Merge.
Generate Bootstrap-ready UI with GPT-4.1, refine with Bootstrap utilities, and import real components into UXPin Merge for code-backed prototypes.
Turn text prompts into production-ready Ant Design React components with GPT-4.1 and sync them into UXPin Merge for interactive, code-backed prototypes.
Turn prompts into production-ready React components and live prototypes to eliminate design-code gaps and speed deployments.
Combine GPT-4.1, MUI, and UXPin Merge to generate production-ready React UI from prompts or screenshots, build interactive prototypes, and export clean JSX.
Generate production-ready UI by combining GPT-5 Mini’s large-context code generation with UXPin Merge for synced, code-backed prototypes.
Combine AI-generated code, Bootstrap components, and UXPin Merge to prototype responsive, production-ready UIs and simplify design-to-development handoffs.
Designers and developers should build UIs from real code to eliminate handoff gaps and deliver production-ready interfaces faster.
Design production-ready React UIs with GPT-5 Mini and shadcn/ui in UXPin Merge — AI builds with real components, syncs with Git, and exports JSX.
Use AI to generate production-ready UIs with MUI and UXPin Merge, sync themes via npm, and build interactive prototypes quickly.
Build production-ready React UI faster by combining GPT-5.1 code generation with UXPin Merge and token-based design systems for consistent, testable prototypes.
Create production-ready React UIs from plain text prompts using GPT-5.1, Bootstrap, and UXPin Merge — generate, refine, test, and export clean code.
