Generate production-ready React prototypes with GPT-5.1, shadcn/ui, and UXPin Merge—create, customize, and add interactions without a separate handoff.
How to prototype using GPT-5.1 + shadcn/ui – Use UXPin Merge!
Use GPT-5.1 with MUI and UXPin Merge to generate production-ready React prototypes, refine designs with AI, and export clean JSX.
AI-driven prototyping that builds production-ready UI from your React components, removing handoffs and accelerating development.
Generate production-ready Bootstrap components with GPT-5.2 in UXPin Merge to build interactive, code-backed prototypes and speed design-to-dev.
Design with production-ready React components in UXPin Merge to build accurate, interactive prototypes, align design and development, and export JSX for handoff.
Design touch-first responsive interfaces with proper touch target sizes, thumb-friendly layouts, scalable typography, immediate feedback, and real-device testing.
Compare centralized, decentralized, and hybrid team models for scaling design systems, and learn governance, maintenance, and scalability trade-offs.
Real-time feedback in prototyping exposes usability issues early, speeds iterations, and aligns design with users via live testing, in-app comments and analytics.
Convert Figma designs into reusable React components with AI—speed UI creation while adding manual logic, accessibility, and design-system alignment.
Eliminate manual token syncing and component drift by automating updates, docs, and governance with AI-driven workflows that keep design and code aligned.
Use semantic HTML (nav, main, button, headings) to provide landmarks and clear structure for smoother screen reader navigation.
UXPin Merge lets teams design and prototype with the same production React components used in their products—whether from standard libraries (MUI, shadcn/ui) or an internal design system—so UI stays consistent, governed, and ready to ship without redesign-to-dev rebuilds. Teams can compose screens manually or use Merge AI to generate layouts with approved components, accelerating iteration
Keep keyboard and screen‑reader users oriented after modals: save the trigger, move and trap focus inside the dialog, then restore focus on close.
Use production-ready Ant Design React components inside UXPin Merge to build interactive, consistent prototypes and export JSX for faster handoffs.
Use GPT-5.2 with Ant Design in UXPin Merge to generate production-ready React components, speed prototyping, and keep design-system consistency.
