Use AI to generate production-ready UIs with MUI and UXPin Merge, sync themes via npm, and build interactive prototypes quickly.
How to build UI using GPT-5 Mini + MUI – Use UXPin Merge!
Build production-ready React UI faster by combining GPT-5.1 code generation with UXPin Merge and token-based design systems for consistent, testable prototypes.
Create production-ready React UIs from plain text prompts using GPT-5.1, Bootstrap, and UXPin Merge — generate, refine, test, and export clean code.
Use GPT-5.1, Ant Design, and UXPin Merge to generate production-ready React UIs, speed prototyping, and export JSX for seamless design-to-development handoff.
Combine GPT-5.1, shadcn/ui, and UXPin Merge to generate production-ready React components, preserve design tokens, and streamline design-to-code handoff.
Use GPT-5.1 with MUI in UXPin Merge to generate production-ready React components from text or images, sync with Git, and export clean JSX.
Use GPT-5.2 with UXPin Merge to generate production-ready React components from your design system, speed prototyping, and export clean JSX for development.
Generate production-ready Bootstrap React components with AI and prototype them as real code in UXPin Merge to speed development and ensure consistency.
Design production-ready React UIs using GPT-5.2, Ant Design, and UXPin Merge—generate real components, prototype interactions, and export JSX without handoffs.
Create production-ready React UI by combining GPT-5.2, shadcn/ui, and UXPin Merge to generate Merge-ready components, interactive prototypes, and direct JSX handoffs.
Generate production-ready MUI React components from prompts in UXPin Merge to speed design-to-code, create accurate prototypes, and sync with Git.
Generate production-ready React prototypes from your design system using Claude Haiku 4.5 and UXPin Merge, keeping design and code in sync.
Use AI to generate Bootstrap React components, import them into UXPin Merge, and build responsive, production-ready prototypes for faster handoffs.
Use production-ready components to sync design and code with UXPin Merge, speed handoffs, and maintain consistent, scalable design systems.
Design with production-ready components and design tokens to replace mockups, keep design and code in sync, and speed development.
