Use GPT-4.1 with shadcn/ui in UXPin Merge to generate real React prototypes from prompts, customize components, and export production-ready code.
How to prototype using GPT-4.1 + shadcn/ui – Use UXPin Merge!
Combine GPT-4.1 with MUI in UXPin Merge to quickly generate, refine, and export production-ready React prototypes using code-backed components and interactive testing.
Turn text prompts into production-ready, code-backed prototypes using GPT-5 Mini and UXPin Merge that adhere to your design system.
Create production-ready Bootstrap React prototypes fast using GPT-5 Mini and UXPin Merge; generate, refine, preview, and export responsive, code-backed components.
Use GPT-5 Mini with Ant Design in UXPin Merge to generate production-ready React prototypes from natural-language prompts, add interactions, and export code.
UXPin Merge lets teams design and prototype with the same production React components used in their products—whether from standard libraries (MUI, shadcn/ui) or an internal design system—so UI stays consistent, governed, and ready to ship without redesign-to-dev rebuilds.Teams can compose screens manually or use Merge AI to generate layouts with approved components, accelerating iteration while
Build interactive React prototypes with GPT-5 Mini, shadcn/ui, and UXPin Merge — AI-generated, production-ready components and exportable JSX.
Combine GPT-5 Mini, MUI, and UXPin Merge to build code-backed interactive prototypes that align with production React components and speed design-to-dev handoff.
Build production-ready React prototypes faster using GPT-5.1 with UXPin Merge to generate real components, layouts, and interactivity from simple prompts.
AI-generated prototypes built from real code components remove handoffs and speed product development with interactive, production-ready interfaces.
Create production-ready React prototypes with AI prompts and real design-system components to speed design-to-development handoffs and ensure consistency.
Generate production-ready React prototypes with GPT-5.1, shadcn/ui, and UXPin Merge—create, customize, and add interactions without a separate handoff.
Use GPT-5.1 with MUI and UXPin Merge to generate production-ready React prototypes, refine designs with AI, and export clean JSX.
AI-driven prototyping that builds production-ready UI from your React components, removing handoffs and accelerating development.
Generate production-ready Bootstrap components with GPT-5.2 in UXPin Merge to build interactive, code-backed prototypes and speed design-to-dev.
