Build production-ready React UIs by generating Ant Design components with Claude Haiku 4.5 and prototyping them in UXPin Merge.
How to build UI using Claude Haiku 4.5 + Ant Design – Use UXPin Merge!
Every enterprise with a custom design system faces the same problem: AI design tools are fast, but they ignore everything you’ve built. Figma’s AI generates vectors. Lovable and Bolt generate to their own component conventions. v0 locks you into shadcn. None of them connect to your existing component library. The result is impressive demos followed
Generate production-ready React UI with AI, reuse shadcn/ui components, and sync live code to UXPin Merge for faster prototypes.
Generate MUI components with Claude Haiku 4.5 and sync them into UXPin Merge for production-ready, interactive prototypes that stay design-consistent.
Generate Bootstrap React components with AI, sync them into UXPin Merge, export production-ready JSX to speed design-to-code workflows.
Generate production-ready React components from prompts, map them to custom design tokens, and sync into UXPin Merge for interactive prototypes.
Use Claude Sonnet 4.5 with Ant Design in UXPin Merge to generate code-backed React UI prototypes faster and export production-ready code.
Use Claude Sonnet 4.5 with shadcn/ui and UXPin Merge to generate code-backed React UIs and speed design-to-development handoffs.
Generate production-ready React UIs by combining Claude Sonnet 4.5, MUI components, and UXPin Merge to align design and code.
Generate production-ready UIs by using AI to place code-backed components from your design system, reducing handoffs and errors.
Generate React-Bootstrap components with Claude Opus, import them into UXPin Merge, and design production-ready UIs faster.
Use Claude Opus 4.5 with Ant Design and UXPin Merge to create production-ready React UIs, align design and code, and speed deployment.
Build production-ready UIs using AI-generated layouts and real components to skip handoffs and export code-ready prototypes.
Use AI to generate production-ready MUI React components, sync them with UXPin Merge, and prototype code-backed UIs faster.
Generate production-ready React UI components from prompts using GPT-4.1 and sync them to your design system with UXPin Merge.
