Build code-backed React landing pages using AI copy, shadcn/ui components, and UXPin Merge to align design, states, and handoff.
How to build a landing page using Claude Sonnet 4.5 + shadcn/ui – Use UXPin Merge!
Map AI-written copy to MUI components and build a production-ready landing page in UXPin Merge to avoid design-to-code drift.
Use AI for copy and map it to code-backed design-system components to build production-ready landing pages faster.
Stop rebuilding landing pages: use AI to generate Bootstrap sections and turn them into reusable Merge components.
Use AI to write copy, map sections to Ant Design, and build a responsive, code-backed landing page in UXPin Merge.
Use AI for copy, map a 6-part blueprint, then assemble code-backed components in UXPin Merge to speed prototypes and handoff.
Turn Claude prompts into a production-aligned MUI landing page with UXPin Merge: map copy to components, build, and test across breakpoints.
Use GPT-4.1 for structured copy and UXPin Merge with Forge to assemble production-aligned landing pages from your design system.
Plan copy with GPT-4.1, map sections to Bootstrap, and assemble code-backed components in UXPin Merge for faster, consistent landing pages.
Create code-backed landing pages: use AI for structured copy, shadcn/ui for typed React sections, and UXPin Merge for prototyping.
Build a code-aligned landing page: GPT-4.1 for copy, MUI components, and UXPin Merge for clickable prototypes and smoother handoffs.
Use GPT-5 Mini to draft copy and UXPin Merge with your React design system to build production-ready landing pages faster.
Turn draft copy into a code-aligned landing page with AI copy, Bootstrap UI, and code-backed prototypes to reduce handoffs.
Turn a brief into a clickable, code-aligned landing page fast using structured AI copy, Ant Design UI, and UXPin Merge prototypes.
Generate component-ready copy with GPT-5 Mini and assemble a code-backed landing page in UXPin Merge using shadcn/ui.
