Generate production-ready React components from prompts, map them to custom design tokens, and sync into UXPin Merge for interactive prototypes.
How to build UI using Claude Sonnet 4.5 + Custom Design Systems – Use UXPin Merge!
Use Claude Sonnet 4.5 with Ant Design in UXPin Merge to generate code-backed React UI prototypes faster and export production-ready code.
Use Claude Sonnet 4.5 with shadcn/ui and UXPin Merge to generate code-backed React UIs and speed design-to-development handoffs.
Generate production-ready React UIs by combining Claude Sonnet 4.5, MUI components, and UXPin Merge to align design and code.
Generate production-ready UIs by using AI to place code-backed components from your design system, reducing handoffs and errors.
Generate React-Bootstrap components with Claude Opus, import them into UXPin Merge, and design production-ready UIs faster.
Use Claude Opus 4.5 with Ant Design and UXPin Merge to create production-ready React UIs, align design and code, and speed deployment.
Build production-ready UIs using AI-generated layouts and real components to skip handoffs and export code-ready prototypes.
Use AI to generate production-ready MUI React components, sync them with UXPin Merge, and prototype code-backed UIs faster.
Generate production-ready React UI components from prompts using GPT-4.1 and sync them to your design system with UXPin Merge.
Generate Bootstrap-ready UI with GPT-4.1, refine with Bootstrap utilities, and import real components into UXPin Merge for code-backed prototypes.
Turn text prompts into production-ready Ant Design React components with GPT-4.1 and sync them into UXPin Merge for interactive, code-backed prototypes.
Turn prompts into production-ready React components and live prototypes to eliminate design-code gaps and speed deployments.
Combine GPT-4.1, MUI, and UXPin Merge to generate production-ready React UI from prompts or screenshots, build interactive prototypes, and export clean JSX.
Generate production-ready UI by combining GPT-5 Mini’s large-context code generation with UXPin Merge for synced, code-backed prototypes.
